跳转到主内容
加入维修社区 - 创建账户
任天堂 3DS 的升级版。它拥有更大的屏幕、更长的电池续航时间、更高的像素密度和更好的设计。
Select button stuck, always pressed
My 3DS XL has had an issue with the select button for a few months.
The button is stuck down and is always recognised as pressed.
I have tried cleaning the button using compressed air and opening up the console to check the contact (which seems to be perfectly clean)
I saw a GBAtemp thread about this issue but the solution was to remap the select button (which I do not want to do).
Any suggestions on how to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi!
The button is directly soldered on the motherboard. Replacing is possible, but won't be easy as you need to (micro) solder the broken one out and solder the new one in.
You could try cleaning the button with isopropyl alcohol and see if that works.
If not, the only options you have is replacing it OR remapping it.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
jimmyapples141 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 7
过去 30 天: 29
总计 172
