I'm not sure exactly what's going on with your phone, but let me clear up a couple of items.
First of all, if you've damaged the flex cable going to the proximity sensor, that same cable also feeds the flood illuminator, which is part of the Face ID system (the proximity sensor isn't part of Face ID). If that part is damaged or replaced then Face ID will not work again unless it is replaced by Apple, or you can use the self repair program which may save you a little money; not enough to be worthwhile though. Apple doesn't replace the front sensor assembly by itself; rather if it needs a new one the only way to do that is to buy a new screen from Apple, which comes with the front sensor assembly.
The second thing I wanted to address is your idea that the backlight is working but nothing else. That's incorrect, as your phone has an OLED display, not an LCD. The difference is that in an LCD display, each pixel open or closes to let light through, but needs a light source; i.e., a backlight. On an OLED screen each pixel is an LED, which generates its own light so no separate source is required.
So if you're seeing any kind of light on the screen then the display is at least partially working, but something else seems to be keeping it from coming on.
The admonition to unplug the battery first and plug it in last is always a good idea, but not as critical as it was with an LCD screen. On a display with a backlight there are generally higher voltages and more current flowing to it that can easily short out when trying to connect the display. It wasn't at all unusual to blow out a fuse or a circuit on an LCD display if done with the battery connected, which is why it's vital to make sure it's not plugged in when messing with the screen. As I said, it's still a good idea but not usually a death sentence on an OLED display.
@flannelist Alisha, do you have any ideas here that might help Marcel?
