跳转到主内容
加入维修社区 - 创建账户
三星在 2023 年 7 月 26 日的“Unpacked”发布会上发布了 Galaxy Flip5 系列。同时发布的还有新款 Galaxy Watch 6 系列智能手表和 Galaxy Tab S9 平板电脑。
Main screen isn't working
I accidentally dropped my phone while it was open and now there's two small pixels on the main screen and it wont let me use certain parts of the screen and randomly taps on apps. How do i get it fixed and through who? The small screen works perfectly fine but the main screen doesn't. They'res also some damage on the outside hinge, but i haven't even had it for a month. Im hoping its not that expensive of a fix
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ik this is a very very response late but the exact same issue happened to a secondhand Zflip5 I bought, and since this could be a very common issue it might help others in the future as well.
So basically if there's damage on the hinge, the flex cable connecting the two sides could be broken causing parts of the screen to malfunction or not work at all. Samsung put the screen connecter on the lower half and decided to connect it to the motherboard through a very fragile flex cable running through the hinge for some weird reasons, so any damage on the hinge or even just too many folds can cause this cable to get worn down, torn and cause things to malfunction. For me it was the phone shutting down completely when I fold it because the cable has fractured, but the same cable could be causing the screen to malfunction for you.
to test whether the cable is broken you can just purchase another cable and attach it directly outside the hinge (as replacing it would require screen removal and is messy in general) to see whether the issues disappeared. If not then the screen is damaged (it is very fragile after all) but if the cable fixed it you can then proceed to replace it and restore its functions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriella weilbacher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 23
总计 202
