跳转到主内容
Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
Why is my screen flickering and backlight completely shutting off?
This happens periodically, I'm sure it has something to do with the display cables.
Does anyone have an idea of how long or where I could find the cables to replace and which ones will actually fix this?
I've tried doing a display update, which fixed it for about a day.
It doesn't happen all the time, but when it does it is very annoying.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
已选择的解决方案
After working on laptops for a while, in my experience, 95% of the time it will be the inverter and 5% it is the LCD itself, both fairly simple to replace.
这个答案有帮助吗?
得分 3
添加一条评论
最有帮助的答案
It's probably not the cables. My guess is your display inverter needs to be replaced.
这个答案有帮助吗?
得分 4
1条评论:
I have this same problem when my brightness is set really low (1-3 bars). I brought my laptop to the Apple store to replace the inverter, but that didn't fix the flickering. At least in my case, I think it could be a problem with the display.
完成的
添加一条评论
If it's flickering, it is quite possible the inverter cable has just come lose and just needs to be reseated. When the backlight goes off, try tapping your top case near the top left and also the clutch cover around the left side. If this resolves it, then the cable may just need to be reseated.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
davidaase 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 17,573
