跳转到主内容
The Visual Land Prestige 10 is an internet enabled tablet made by Visual Land INC. This device page and subsequent repair guides will show you how to remove and replace the devices components.
How to get my physical keyboard to work?
How to get physical keyboard to work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi @wendybair
Try using an OTG adapter cable to connect a USB keyboard to the tablet and check if that works. (supplier example only)
Be aware that the tablet will power the keyboard which means that the tablet's battery will discharge faster than it normally would.
这个答案有帮助吗?
得分 1
添加一条评论
It looks like Wendy Bair is asking for help getting their physical keyboard to work with their Visual Land Prestige 10 tablet.
Here are a few things they could try:
  • Check the connection: Make sure the physical keyboard is properly connected to the tablet, either via a USB cable or Bluetooth. If it's Bluetooth, ensure it's paired correctly.
  • Restart the tablet: Sometimes a simple restart can resolve connectivity issues.
  • Check keyboard settings: On the tablet, there might be keyboard settings that need to be adjusted. Look for input methods or keyboard options in the settings menu.
  • Try a different keyboard: If possible, try connecting a different physical keyboard to see if that works. This can help determine if the issue is with the keyboard itself or the tablet.
  • Check for driver updates (if applicable): If it's a specific type of keyboard that requires drivers, ensure they are installed and up to date.
Hopefully, one of these suggestions will help Wendy get their physical keyboard working!
这个答案有帮助吗?
得分 -2
1条评论:
@vedangupadhyaya while AI can be a useful tool for some things, us moderators here at iFixit do not feel it can be relied on as a sole authority for answers to repair questions. So while we won't remove your answers , we would strongly request that you indicate that your answer is generated using AI so our users can judge the accuracy of the answer for themselves based on that knowledge.
Thus far all of your answers have been AI generated which is not what we do on here! Your AI answers do not provide any solutions and are therefore misleading. Since you have been informed of this numerous times ,be aware that you are running risk of getting this account banned as well.
完成的
添加一条评论
添加你的答案
Wendy Bair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 100
