跳转到主内容
加入维修社区 - 创建账户
The DualShock 2 Analog Controller first appeared with the PlayStation 2 and featured only minor cosmetic changes in screw locations etc.
left analog stick is becoming increasingly squeaky
Hello,
My Dual Shock 2 is still working well after all these years! However, the left analog stick is becoming increasingly squeaky, and has begun to stick on rare occasion, but still functions near perfectly 99.9% of the time. Is there a simple trick to loosen the stick, and perhaps any buttons such as square and X, to prevent squeaking and sticking, using a household lubricant product such as WD 40?
Thank you,
Daniel McNamara
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Daniel!
First I would try to clean everything in there.
You can just use a wet cloth and clean it (make sure that the cloth is not too wet!).
For the stick, you could use ispropryl alcohol and clean it and see if that makes a difference!
If not, then you might want to replace the stick (worst case).
Please let us know how it goes and good luck!
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
D_mac08 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 31
过去 30 天: 138
总计 1,478
