跳转到主内容
The Asus A541U line is part of the Vivobook Max series by Asus. These include the models; A541UA, A541UAK, A541UJ, and A541UV released in various years.
Power Button doesn't work
The button doesn't respond at all
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@siphumelel69527 have you checked for power on your laptop? Any LCD's lighting up or blinking when you connect your power adapter?
完成的
添加一条评论
1个答案
Well try the following it some the basic way to fix this issue:
  • Check charger & power outlet: Ensure the laptop is plugged in and the outlet works.
  • Battery indicator: If any lights turn on when plugged in, the laptop may still be functional.
  • Unplug the charger and Remove the battery (if removable) And then Press and hold the power button for 30 seconds.
  • Reconnect the battery and charger, and try turning it on.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Siphumelele NDLOVU 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 6
总计 87
