跳转到主内容
加入维修社区 - 创建账户
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
Xbox controller not connecting or responding
Hello
Recently purchased and xbox which wouldnt power on and i found all sorts disconnected and ive got it working again. Its now a week later ive powered it on and it wont sync my controller via usb or bluetooth.
It detects my controller via usb as the controller vibrates but it wont sync, also i can connect to the xbox via the app using my phone as a remote and it shows on the screen it recognises i have connecting BUT it wont respond to any commands.
Will this be a synch and bluetooth board that needs replacing along with the ribbon cable? Or the accessory board?
Thankyou in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
It does sound like the bluetooth board need to be replaced. I would do this first and see how that goes.
The issue you are describing is a bluetoothish issue.
If you need guides, please let me know!
这个答案有帮助吗?
得分 2
6条评论:
I did find it odd how it would connect via the phone app but wouldnt recognise which buttons were being pressed.
If i knew the ins and outs of how it processes the information through the boards then it would make more sense.
Their is very little out there in the way of people encountering this issue and a fix for it but im glad you have confirmed my suspicions.
I will let you know if this fixes it.
Thanks again!
完成的
My pleasure! It is. Microsoft won’t give any details on that, I think. Anyway, please keep us posted! Thanks :)!
完成的
Hello
So an update .... the bluetooth board did not fix the issue. However i do have a replacement ribbon cable for the sync board - mother board connection. I noticed initially that it looked like there was a severe bend in it and that under the insulation it was possibly broken so i ordered a replacement at the same time as the board. Cable arrives tomorrow so i will let you know.
完成的
Okay! Hopefully that is it. Otherwise it could be motherboard related… let’s hope for the best!!!
完成的
Turns out it was the ribbon cable! Installed new one and everythings working. Annoying as i went and ordered a sync board because i continuity tested the original cable and it came up it was ok.
Owell parts for the future. Thankyou for all your help!
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Steven Hall 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 34
过去 30 天: 160
总计 855
