跳转到主内容
Repair guide, disassembly, and troubleshooting information for the Logitech MX Master 3S wireless mouse. Released in 2022 and identified by model number MR0077.
Both left and right buttons malfunctioning
Less than a year after purchasing the MX Master 3S, the left button started to not register clicks (about 2/3 of the time) and shortly after, the right button followed the same issue.
I would really like to have a guide on replacing switches and the parts that fit here.
Thanks,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi mate,
This seems to be a very very common issue on these mice. My MX anywhere 3 is doing the same thing with the right click after 4 years where it feels mushy, like something's dislodged.
Because logitech & iFixit have partnered, there are guides on this very website on how to disassemble the mx master 3s, and given the one you want isn't there you can always reference the master 3 guide, since they are very similar.
As for where to find the parts, Logitech isn't selling them here as they likely require resoldering. What you could do however is to open up the mouse, check what the part number is and given you are able to solder, order one yourself & do the repair.
If you don't want to do the repair yourself, there's a chance your local repair shop might do the repair for you since it's a small soldering job. Otherwise i don't reckon Logitech are going to do replacements on that mouse.
Do note, since this is less than a year old, you should be able to claim with logitech given the 1 yr warranty.
这个答案有帮助吗?
得分 0
2条评论:
I just passed the warranty :( lol.
The opening guide currently on iFixit does not include replacing the switches, nor dose it mention parts that would work.
Logitech has replaced the switch from MX 3 to a drastically different type for MX 3S. I placed an order for a couple of Kail Mute 6 x 6 x 7.3 switches, will update if they fits.
完成的
Hi Kevin, any luck with those switches? I'm in the same boat as you are.
完成的
添加一条评论
添加你的答案
Kevin Xu 将永远感激不已
浏览统计数据:
过去 24 小时: 17
过去 7 天: 90
过去 30 天: 427
总计 2,468
