跳转到主内容
加入维修社区 - 创建账户
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
My laser doesn't work
I tried to understand what is the problem, and maybe i have the solution too, but firstly I want to be sure of what I'm fixing, before I take another laser that costs money ☺️. The CD doesn't spin, but it seems that this is due to a lack of power coming from the mother board. On the cable that comnects the mother board to the optic group there is a little black dot. Chatgpt says that it is a burn caused by some sort of electricity malfunctions.
Can anyone help me?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Hi!
It's hard to say without photo's. Can you share them with us?
Anyway, it's possible that some capacitors failed on the motherboard and prevent the Playstation it's drive from working.
Also, the laser could have failed.
But before we can tell, we really do need pictures.
Thanks!
这个答案有帮助吗?
得分 2
添加一条评论
Hi there!
thank you for your answer, really appreciate it. This is the photo of the black dot on the cable. Tell me if you need more, thanks for your help!
这个答案有帮助吗?
得分 0
1条评论:
My pleasure! Thanks for the photo! This is not a burn mark. This is straight from the factory. Some ribbons do have marks (rare, but it’s there). Most likely thing is that your laser just died or starting to die. I would replace the laser deck as complete. A new laser deck comes with everything, including a new ribbon cable. The cable is fused, so it cannot be replaced (everything is replaceable, but it will be VERY difficult). The only thing you need to transfer is the power cable, and that’s it.
完成的
添加一条评论
Here there are some photos of the motherboard, if you see any problem let me know. Thanks for your answer by the way, I just want to be sure making you see these pictures, even if I think it seems ok. Thank you very much!
这个答案有帮助吗?
得分 0
1条评论:
Hi again!
The motherboard looks fine, but it is modded. Be aware that a broken modchip can cause issues with reading games. So it’s either your laserdeck or the mod chip.
完成的
添加一条评论
添加你的答案
Francesco Avantario 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 103
