跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Left Speaker Replacement Does Not Work
Replacement speaker has very low volume and the sound is tinny. Is this the part or something I have done?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@gilipatric84137 quick Question. why did you replace the speakers? What was wrong with them in the first place?
完成的
添加一条评论
2个答案
That sounds like a bad speaker. Where did you get the part? See if they will send you a replacement.
这个答案有帮助吗?
得分 0
添加一条评论
The original & OEM speakers for these 13" & 15" Retina models are 'not exactly of the best quality" and are notorious for failing easily, depending on your location give The BookYard a shout to see if they have an original set in stock as they do ship orders out worldwide.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gilipatrickr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 108
