跳转到主内容
第六代 iPod nano 的维修信息。发布于2010年9月。机型型号 A1366。
Volume Button is Stuck. Can it be fixed?
The Volume up button is stuck. Can this be fixed? It's only a six months old.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
It should still be covered under warranty.
完成的
添加一条评论
4个答案
已选择的解决方案
Yes it can!!!! I'm amazed. I'm no techie and have no experience with electronics repair and I was able to fix my stuck volume button. I opened the ipod up, removed the battery, and all the sticky tape that was in my way and necessary screws. There was a little (pinhead sized) black rubber(???) circle that was suppose to be stuck in the center of the copper colored volume button that had come lose. I used a little glue stick glue to put in back in place. I'm not sure if I will need to redo this with better glue, I just used what I had. Put everything back together and it works!!! The volume button and everything else. The only problem is that the glue is not as strong as it was and the screen is loose. I'm going to see what I can find to glue it back in place.
这个答案有帮助吗?
得分 0
2条评论:
Hi!! Thank you for your answer. How did you opened up the ipod?? I don't want to break the screen :/
完成的
Yes, I cannot see any way to open I Pod. The back just opens slightly to use on an arm band.
完成的
添加一条评论
I have the same problem with my ipod nano. Could anyone help us? Thanks
这个答案有帮助吗?
得分 0
添加一条评论
Here this gives some more hints:
http://www.rbarrios.com/projects/NANO6BU...
I tried it, got the button back to press the mico-switch. But it still doesn't work. No effect when I now press it. Not sure how the electrical setup works as I don't understand where the micro-switch needs to be connected to.
这个答案有帮助吗?
得分 0
添加一条评论
you could use Apple Earphones with Remote to change the volume even though the buttons don't work
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jmoore21591 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 26,246
