跳转到主内容
A 14" enterprise laptop by HP, released in 2013.
My PC does not turn on when power button is pressed
When you press power button, it displays the yellow light then off. It does this repeatedly until you force it to turn off by holding the power button
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Take a look at the keyboard caps lock key and listen for beep codes. 95% of the time, it is bad RAM or corrupted CMOS settings (SureStart machines only) due to how stringent HP is at POST about RAM quality on the Pro and Elite series. The HP Z series is far less forgiving, but these non-Z machines at least give you some room for error.
What is the pattern? The procedure for accessing the RAM and CMOS batteries is in the HP SM. Refer to this for POST codes.
Look at the pattern on the caps lock key, write it down and report back:
这个答案有帮助吗?
得分 1
1条评论:
There's no any beeping sound on the caps lock button
完成的
添加一条评论
添加你的答案
Bry Xhu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 131
