跳转到主内容
加入维修社区 - 创建账户
苹果第四代智能手表,带有可选的蜂窝网络功能,于2018年9月21日发布。
Can't open watch
I have a Series 4 40mm SS.
I bought the iFixit kit to replace the battery. However I can not get under the screen to lift it using the scalpel. I've applied the iOpener heat mat several times, to the point the watch is too hot to handle. I just can't get enough purchase. I've tried lightly, with force, and all along the edges. Advice would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
I created a wood block to hold the watch as it’s just safer. The trick is to aim the knife curved edge downward between the case and crystal parting the two from each other, then once I’ve gotten the knife edge into the space I twist it in a prying action under the crystal. You do need to keep the pressure on the knife.
这个答案有帮助吗?
得分 0
添加一条评论
Use a small suction cup if you have one to lift up the display similar to phone repair
Force the blade under the screen (carefully of course)
这个答案有帮助吗?
得分 0
添加一条评论
I had to buy Dorco (razor) blades to get a thin enough edge to get between the case and screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ryan 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 25
总计 253
