跳转到主内容
The rotating side brush is no longer rotating
I've unscrewed the screw that holds the brush in place, removed the brush, cleaned the area, and reinstalled the brush without success.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
As it appears that you've already taken a few easy steps without success, there is most likely something wrong with the side brush motor assembly.
Luckily an awesome Ifixit contributor has created a guide on replacing it!
it can be found here:iRobot Roomba 630 Side Brush Motor Replacement
while the model number is different it shares the same construction and should still work.
Hope this is helpful!
这个答案有帮助吗?
得分 0
1条评论:
Thanks! I've ordered a replacement motor. Hopefully that will do it.
完成的
添加一条评论
添加你的答案
Carorhoomba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 24
总计 24
