跳转到主内容
型号 A1238 / 80, 120, 或 160 GB 硬盘 / 黑色或银色面板
904 个问题 查看全部
Why can't my iPod charge?
I've got a very big problem.From time to time,iPod doesn't want to charge..it overheats i f I put it on charge many times,and sometimes it's blank-it shows that I have no music,but that I have 1809 songs,which I do...and it also freezes from time to time....help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Luna, it appears like you are having multiple issues. The overheating can be caused by a bad battery or the power management IC. The files not showing up can be firmware related as well as hard drive issues, so can the freezing. I would start by replacing the battery, reevaluate and see what it does. You can get a USB-to_zif adapter to check the integrity of your hard drive. Run the internal diagnostic test and see if it passes all those. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
but sometimes.i think this is NOT caused by overheating or something.before i have this fault,too.i just have 32 song.it still normal.secong time,i sync with itunes and i have about 10 songs or less.the third time,i syce with itunes too and i have about more than 200 songs.BUT after that,sometimes i try to connect with pc and it can't and now,when i try to recharge by plug into a power outlet(you know it,i think) and it cannot recharge.BUT when i breaking up the source at the ipod source.it charge BUT when you using.it cannot charge.you must turn it stand by by hold the play button for a few second.so it charge.works for me.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 1,613
