跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Lines! When I alter the displays angle
Hello. There are horizontal lines and doubling text on my A1534 screen.
I suppose its one of the flex cables that connects to the screen as the lines and flickering changes when moving the lid. Is that flat ribbon changeable or is there something thats attached soldered to the screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sadly, the LCD ribbon cables from the T-CON board which is the part that dangles from the display is the issue. Here’s an image of the cables
Review this guide Retina MacBook 2015 Display Assembly Replacement see if the cables are damaged or the insulation is worn off. Sometimes wind blown grit can get in and over time the insulation gets worn away. Otherwise you’ll need a new display.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GJN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 58
