跳转到主内容
加入维修社区 - 创建账户
The PSP 3000 was released in the U.S. on the 15th of October 2008.
WLAN switch is not moving
I’ve recently gotten a PSP 3001 and I was trying to connect to the internet but to my surprise the WLAN switch was jammed and just not moving no matter what. I’m not an expert with disassembling electronics but I will if I have to. Anything helps
Update (03/04/25)
Here’s a vid of it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Hi! Can you share a video with us?? Thanks!
完成的
@dan0 just edited the question with one if you wanna take a look
完成的
Hmm, it won’t play. Can you upload it somewhere and share it? Sorry!
完成的
@dan0 that’s fine, I’m uploading the vid to YT rn, my service isn’t that good tho so it might not upload for a while, I’ll update when it does
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Thanks for the video! That worked :)!
Okay, now the only question is, is it the switch it self or is the shell where it’s stuck at.
I recommend to open it up and inspect this! If it is the switch it self, then you do need to replace that one! Unfortunately, it’s soldered on the motherboard… so you do need soldering experience to replace it. If it is the shell, then you can replace the shell to get it fixed! Either way, it does need to be opened so you know for sure what it is. Sorry!
这个答案有帮助吗?
得分 1
2条评论:
Thanks for info, though my solution was a little stranger. When I had gotten home it had just randomly started moving smoothly again? Weird but my top theory is my old battery was starting to get bloated and it maybe was pushing the shell to make it harder
完成的
Ahh, never knew that a swollen battery could cause this. I know that the original batteries are getting bad and do swell a lot these days. Good to hear that it is fixed now :)! Have fun gaming and take care!!
完成的
添加一条评论
添加你的答案
BurgerMan101 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 42
总计 521
