跳转到主内容
加入维修社区 - 创建账户
POCO X3 NFC Android 智能手机(型号 M2007J20CG)的维修、拆解及故障排除信息。它配备骁龙 732G 处理器、120 Hz 显示屏、6400 万像素四摄、NFC 功能及 5160 mAh 电池。
Why won't it charge anymore?
My friend's phone has had it for 5 years and suddenly it won't charge. I cleaned the port with toothbrush and isopropyl alcohol and nothing. Before I did it though, I did try to charge it on 2 different chargers, a 45w and 65w, and on the 2nd it turned on from being dead and was charging for around 10 seconds before it turned off. Now, it won't display anything, only the white led on top.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
باد کردن باطری گوشی
完成的
Motherboard change
=== Update (08/24/25) ===
How to motherboard change
完成的
O celular não está ligando
完成的
Poco x3 ka madhur board
=== Update (02/08/26) ===
Poco x3 ka madhear board
完成的
添加一条评论
3个答案
最有帮助的答案
Hi @henryares,
Best I can find online is that the phone is designed to be charged using chargers up to 33W only.
Hopefully you haven't damaged the battery management circuit in the phone by using a 65W or even the 45W charger. You should be able to use these as normally the battery will only draw as much current as it needs to, but given that Xiaomi is being specific about it being "up to 33W" I don't know.
Perhaps check that the main flex cable between the charge port board and the mainboard is securely connected at both ends.
If it is then you could try replacing the charge port board and see if that fixed the problem.
Here's a video that shows how to replace the charge port board that may help. It will also allow you to check if the main flex cable connections are secure as well
If you decide to replace the charge port board, search online for Poco X3 charge port board, to find suppliers that suit you best.
这个答案有帮助吗?
得分 2
添加一条评论
Estava com esse problema também, consegui resolver com outro cabo flex da Sub placa
这个答案有帮助吗?
得分 0
添加一条评论
In the Poco X3, X3 NFC, and X3 Pro, there’s a plug-type socket that can sometimes come loose or even detach. Fixing it is pretty simple—once you remove the back casing, the job becomes much easier. All you’ll need is a Phillips screwdriver to unscrew the cover above the battery. Then, check the wide ribbon cable running over the battery to see if it’s loose. If it is, secure it—and you can thank me later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Henry Ares 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 25
过去 30 天: 141
总计 2,285
