跳转到主内容
The Canon PowerShot A710 IS is a compact and feature-packed DSLR released by Canon in 2006. It also comes with numerous accessories to make it an even more reliable machine to take on-the-go.
2 个问题 查看全部
Camera's battery latch broken and it won't turn on.
The camera won't turn on.
The battery door closes but it gets detached easily.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@mehtabsing76021 you will need to try to replace the screws that hold the cover to the mechanism. If that does not work, it is possible that the screws no longer properly hold. In that case, replacing the plastic cover should fix this. This Canon Powershot A720 IS Battery Contacts Replacement should be identical to your camera.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mehtab Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 20
