跳转到主内容
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
74 个问题 查看全部
Where can I download the drivers
where can i download the drivers
Acer Aspire One ZG5
display
ethernet
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
已选择的解决方案
Right off Acer's website.... These links should work fine for you.
Display Driver - http://global-download.acer.com/GDFiles/...
LAN - http://global-download.acer.com/GDFiles/...
Wireless LAN (not sure if you meant this) - http://global-download.acer.com/GDFiles/...
这个答案有帮助吗?
得分 3
3条评论:
do they work with wondows vista
完成的
Um... no... Acer seems to have only the XP versions... did you put Vista on this machine yourself?
完成的
yes I need the lan driver, vga display driver
完成的
添加一条评论
Hi Liz,
I have a couple of Acer laptops; (different models just to make things a bit more interesting!) I have always managed to get the driver that I want from the link below.
www.acer.com.au/ac/en/AU/content/home
Hope this is of some use to you?
Cheers Al.
这个答案有帮助吗?
得分 2
添加一条评论
Hi, try this:
http://acer.supportscentre.com/driver-of...
这个答案有帮助吗?
得分 0
1条评论:
If you do not need Windows operating system, i install Xubuntu from: http://xubuntu.org/
burn it, boot xubuntu cd, choose "TRY Xubuntu" (loading operating system something like Windows Live), connect your internet, and choose install xubuntu now.
Install with all drivers, no need download drivers, all is automatic.
I recommended.
Thank you.
完成的
添加一条评论
You need to go to acer official sites and then you need to click on this link http://www.acer.co.uk/ac/en/GB/content/g....
now you need to select your os type and then will get your drivers.
Else you need to download driver checker on your computer and then you need to run it. once you will run it then it will detect the drivers and download the drivers for you automatically.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
LIZ 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 55
总计 36,647
