跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
How to fix a sunk in power button
So, my iPhone4 was perfectly fine until a couple weeks ago. I took it out of my pocket and I discovered that the power button had "sunk" in. It still functions; however, there is no click or resistance when I press it down. I have to push a lot harder in order for it to properly work. I have take then entire phone apart in order to attempt a fix, but I cant figure it out. The power sensor cable seemed perfectly fine (the yellow 'nub' was still intact). Any suggestions on what I can do to restore the original function and regain the clicking?
Any help would be greatly appreciated.
also, theres no water damage nor has the phone been dropped.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Unfortunately that is a common problem on the iphone 4.
The problem is that originally there is a small black 'dot of plastic' on top of the switch (on the flex) which activates the switch when you press.
Most likely this black dot has disappeared from your switch. The best way to solve this is to replace the power and sensor flex assembly:
[关联产品丢失或禁用: IF189-004]
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 23,330
