跳转到主内容
加入维修社区 - 创建账户
任天堂于 2021 年发布的 Switch OLED 机型的维修和拆卸指南。
Switch oled won't charge or respond at all
my switch oled randomly over the holidays stopped receiving power after about 3 weeks of use. It will not charge at all, I've used multiple cables and it still won't charge, the dock also won't recognize it's on it at all. No charge led or anything. I've tried to do the power cycle things, holding the power button for several seconds and such. I've removed the joycons, game card and SD card and it still has no response. I have a repair kit, I just don't know what is wrong with it so I can get the new parts. If anyone has any recommendations please let me know, this has been a crisis for almost 3 months. I'm having a hard time diagnosing the issue and don't even know where to start. Any advice would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Jack!
Well, could be a lot of things.
The dock won't recognize it? Could be the USB-C port...
What I always do, is temporarily use a fully charged (new) battery and see if it want to turn on.
If the Switch does turn on, then put the charger in. If it is charging, then it's probably the battery which need to be replaced. If it won't charge, then you might want to replace the USB-C port. If it's still not working after replacing the USB-C port, then it's motherboard related.
So I recommend to try a fully charged new battery first and see what happens. This will help you troubleshooting.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jack Posey 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 90
总计 1,118
