跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Why is there a "no service" or "sos only" after water damage?
HELP!
I dropped my phone in water today and ive kept it in a bag of rice all day!
Its started working again, full function of my touch screen and eveything else!
But i cannot get any service it just says "sos only" and "searching" sometimes!!
HELP ME!!!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
raquel, since your water damage is still recent I strongly suggest that you clean your iPhone. The rice is a great first aid , but it does not clean nor repair your phone. If you do not clean it properly, you might run into corrosion damage later on. First thing you want to do, is to not try to turn your phone on anymore until it is cleaned. If you continue to turn it on, you are running risk of shortening out the logic board and its components. Use this guide to clean your phone. After you cleaned it, replace the battery. Reevaluate for any damage after you do those things. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,195
