How do I fix my stiff thumbstick?
When turning the thumbstick in any direction, once letting go, it does centre itself and stays turned the direction i turn it to.
Common issues related to a stiff thumbstick include dust or dirt getting into the DualSense (PS5) Controller V4, internal misalignment or stick drift issues. Here’s how you can fix it:
Check for Dirt & Debris
Move the thumbstick in circles and see if anything sticks.
Then shoot a can of compressed air around the base of the thumbstick.
Clean edges having a soft brush or cotton swab using isopropyl alcohol (70% or better).
Reset the Controller
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 48
过去 30 天: 205
总计 3,176
Hi!
Which thumbstick is it?? I would replace the joystick, this will most likely fix it.
由 koppie007 完成的
The Left thumbstick
由 Money Vlogs 完成的
How to fix stick drift
由 Aleem Hussain 完成的
You can try this one first: DualSense Controller V2 Stick Drift Fix
Otherwise you need to replace the whole joystick: DualSense Controller v2 Joystick Replacement
Good luck with the repair!
由 koppie007 完成的
