跳转到主内容
加入维修社区 - 创建账户
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
Screen won't wake up after sleeping until force restart
Hey bro i have an iphone 11 pro got its screen replaced a 2 months back and now after some time i leave it its display wents black but the phone works and after force restart it goes back to normal ,but note nothing happens while i am using it whenever i leave it and after some time i look back at my phone to use it it does this thing i thought it was the battery but it isnt i replaced it a week ago ,Note that my phone is fine while i am using it its screen only goes black when i dont use it for some minutes,Also i data analyzer says nand or CHarging flex or power button flex is the issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Haseeb, I've switched your question from an answer on an iPhone 12 question to a properly categorized question under the iPhone 11 Pro device type. You are much more likely to get a relevant answer this way, as your question was only tangentially related to the original question.
完成的
添加一条评论
2个答案
最有帮助的答案
Well the most basic fix to this solution is to update your iphone to it latest software version this ca help you in fixing the issue. Sometimes outdated software version can also cause this kind of issue.
这个答案有帮助吗?
得分 1
添加一条评论
Haseeb, your first task is to get us some information about the problem on your phone. Chances are pretty good that there are files called panic logs stored on your phone that may be able to tell us what's going on with it. Your job now is to read the Kernel Panics wiki page and use the information there to locate and copy the first page of the latest panic log you can find.
iPhone Kernel Panics - iFixit
Once you have that, come back and edit your new question to include a screenshot or cut'n'paste of that first page.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Haseeb Waris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 81
