跳转到主内容
The Hisense 32H4C model is a 32-inch high-definition television with a light-emitting diode (LED) display.
Why is it that my remote control is not working?
Why is it that the led light is not blinking when I use the remote control?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
If you haven't already, try replacing the batteries of the remote, and check the battery terminals for corrosion. Even if you see none, use sandpaper, nail file, or some abrasive to clean the terminals. Also check to make sure nothing is obstructing the IR sender on the remote and the IR receiver on the TV. If all else fails, a new remote may be in order.
这个答案有帮助吗?
得分 1
1条评论:
Yes but still not working
完成的
添加一条评论
Hi @jangirjangir
What is the model number of your TV?
Try using a digital camera or the camera in a mobile phone to prove whether the problem is the remote control or the IR receiver in the TV.
Turn on the camera or open the camera app in the phone and then point the end of the remote that is usually pointed towards the TV so that you see it in the camera's screen.
The press the Power button on the remote. If it is working you should see a flashing light at the end of the remote when you look at the camera screen.
If you don't see a light flashing then try another button on the remote to see if it works.
If no button works at all, then the remote is faulty.
If only the Power button (and perhaps also the Volume Up/down and Channel Up/down) don't work, but all the other buttons do work, then the button's contacts may be dirty or worn away. You would have to open the remote to fix the problem.
If the power button on the remote works then the IR receiver in the TV may be faulty
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Angelius Rashid 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 24
过去 30 天: 137
总计 386
