跳转到主内容
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117 个问题 查看全部
My iBook turns off when plugged into the AC adapter?
I got a new battery for my iBook, that would not charge or turn on when plugged into the AC adapter. With the working battery, I installed a fresh copy of OS 10.2 onto the new hard drive,
Unfortunately, the iBook does not turn on if it is plugged into the AC adapter. When it is on from the battery's power, plugging in the AC adapter immediately shuts it off.
I thought that resetting the PMU would help, but my model doesn't have a physical reset button, so I press the key combination. Pressing this combination results in the iBook powering down, but it would power down anways if I had just pressed the power button. I can't tell if I'm successfully resetting the PMU. After what should be a PMU reset, the iBook still does not power on when plugged into the adapter, and will still shut off once I do plug in the AC adapter
Any advice is greatly appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Looks like a DC in board issue. What is your iBook model (speed in MHz) ?
You say: <<...When it is on from the battery's power, plugging in the AC adapter immediately shuts it off...>> That's why I would suspect a faulty DC in board.
To reset the PMU please check this link:
http://support.apple.com/kb/HT1431
这个答案有帮助吗?
得分 2
4条评论:
The scary thing is that I've already replaced the DC-in board already. My model is the iBook 900Mhz 12". I reset the PRAM and NVRAM, and PMU as per the instructions on Apples' support page. The timeline of trying to get this iBook working again was after I replaced the hard drive. When installing 10.2, the battery was getting low, so I plugged the AC adapter in, which caused it to shut off. Since then I've replaced the battery, the DC-In board, and the AC adapter with no success.
完成的
I guess you tried the AC adapter without the battery installed with the same result ? Last troubleshooting step would be to disconnect all the cables on the logic board but the video cable and trip the two pins in the power switch socket to boot the machine. If you still have the problem then the logic board is bad. I often test logic boards with nothing connected only an external monitor, heaphone (to hear the chime) and a known working dc in board. If the board boot to the question mark screen then most of the time the board is OK and something else is causing the problem.
完成的
Yes, with no battery and just the AC plugged in, it's the same result. I guess I might dissemble it once more, leaving only the display plugged in. You mention "tripping" the two pins (I know which ones they are though) that are responsible for the power button. How would I go about doing this?
完成的
simply disconnect the power switch cable connector (blue & white wires) from his socket then use a small jeweller flat screwdriver and briefly short the two pins inside the connector, the iBook should start. If everything is disconnected from the logic board I use headphone or external sound system to listen to the boot chime.
完成的
添加一条评论
Look at the tip of the AC adapter and see if it is broken off (if it is, the tip is probably in the DC IN port). Let me know and we'll go into replacement of this port.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JayCee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,489
