跳转到主内容
马自达汽车的修理和支持指南。
283 个问题 查看全部
Fix the driver's side door interior panel in Mazda Tribute SUV?
The interior driver side door latch no longer works. I suspect the linkage inside the door has broken or come apart. I need to know how to disassemble the door panel to gain access to the door latch mechanism.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Tom, what year is your tribute?
完成的
添加一条评论
2个答案
已选择的解决方案
Tom, you forgot to tell us the year of your vehicle. This should work for you "1. Remove the door sail panel. If equipped, disconnect the power mirror electrical connector. LH side shown, RH side similar. 2. Open and remove the door handle finish panel. Pull the door handle outward to fully access the door handle finish panel. 3. 4. 5. 6. Remove the door handle screw. Remove the door inside handle screw. Remove the 3 door trim panel screws. Remove the door trim panel. Pull outward and then upward on the door trim panel. Disconnect the electrical connectors. 7. Remove the door handle from the door trim panel. Disconnect the electrical connector. Press the 2 retaining tabs while pushing the door handle from the door trim panel. Remove the door handle from the door trim panel by pulling it back through the door trim panel. 8. To install, reverse the removal procedure." from [http://Mitchell Repair Information Company,|here]
这个答案有帮助吗?
得分 3
添加一条评论
I have a 2004 Mazda Tribute drivers door will not close it won't latch when you shut the door how do you fix this.
这个答案有帮助吗?
得分 0
3条评论:
i have the same issue 2001 tribute. I slammed the door close it is shut but now exterior handle is loose and not working, while interior is also not working and the lock button seems jammed
完成的
Some issue with the passenger door. Anyone have the schematic for that door?
完成的
@rottjocky what make and model vehicle are you inquiring about? What is going on with your door?
完成的
添加一条评论
添加你的答案
Tom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 8,019
