跳转到主内容
Epson EcoTank L3150 Wi-Fi All-in-One Ink Tank Printer
20 个问题 查看全部
My printer doesn't turn on.
I've already replaced the power supply but the problem remains. Is there a possibility the main board is faulty or do I have to check something else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
@maddog571998 sounds like a main board issue but lets see if our printer guru @nick has a better suggestion
完成的
添加一条评论
1个答案
已选择的解决方案
I'm assuming you checked the connections and all of that, so the next thing I would do is check for a pinout on the power supply (the last Epson I had was an NX415, which I believe had it on the supply). Take note of that power supply pinout, and get a multimeter (even a basic Walamrt meter will work here). Look for something like this, a $20-30 meter will suffice.
Plug it into the printer just in case there's a signal wire. I don't believe this is a thing with Epson power supplies, but if it is, you will need to plug it into the motherboard OR jump it. It's easier to do it connected to the motherboard. If there's no immediate ground, you can use your household ground in a pinch, but please try to find an LV ground on the board or something else to avoid as many issues as possible. It will probably work, but I don't like using a household ground when it's avoidable (and it usually is). If the voltages are exact (or marginally higher) then the supply is rated for, you have a motherboard issue or something else is off like the control panel. You might get lucky and find it's the control panel wire, but very often a bad board.
Versatile multimeter with all the right functions for basic electronics troubleshooting.图片
产品
Digital Multimeter
$19.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Γ Σ 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 53
总计 123
