跳转到主内容
加入维修社区 - 创建账户
FixHub Power Series | 便携式焊接站的维修和故障排除信息,便携式焊接站和智能烙铁的组合。2024 年 10 月发布。
Soldering tip not recognized when powering on the iron
Dear all,
my hub is running on firmware 1.06 it starts up normally and recognizes the tip in the iron:
When I switch the iron itself on, the hubs suddenly says that there is no tip connected.
Switching the hub off and on again leaving the iron in the same port shows the same error.
When I plug the iron to the other port and cycle power of the hub, it works until the next restart of the hub.
I already tried another tip but that didn´s solve the problem:
Do you have any idea what to do?
Best regards
Andreas
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Hey there Andreas, is this iFixit's Soldering Iron or a different brand of soldering iron?
完成的
Hi Jacob,
it is the new iFixit iron.
完成的
@karapiepenbrink Any thoughts on this one?
完成的
Hi Andreas, have you tried setting the soldering iron switch to ON before connecting it?
Another solution or workaround you can try is to hot swap ports with the iron switch on.
Pull the plug on the iron (especially if there is a blinking fault indicator) while it is powered up, and plug it into the other port on the Portable Power Station. You can also try entering into the settings mode and then exiting it when you do this.
完成的
@karapiepenbrink
Hi Kara,
yes, when I change the port of the iron while beeing in the settings it works. Without beeing in the settings the iron does not get recognized on the other port.
It really looks like a software problem.
By the way... When i Connect the iron as a 'normal' USB device (eg by using a USB Ampere and Volt meter, there is now problem at all. Again... i think it´s a software problem.
完成的
添加一条评论
2个答案
最有帮助的答案
The update to firmware 1.07 (which is available again) seems to have solved the problem.
这个答案有帮助吗?
得分 1
2条评论:
Sorry to say that the propblem isn´t gone.
That rerally !#^&@! me off!
完成的
We're actively working on a solution and will have it ready for you as soon as possible.
完成的
添加一条评论
Hi Andreas,
I hope that you have found a resolution to this issue with our support staff. The situation that you saw with the tip "present" until you turned on the switch has to do with the internal thermocouple of the tip and how we detect whether or not a tip is installed. In short, there is a fault in the temperature feedback loop on your iron that the iron didn't detect until the power went on. You would need a replacement iron, as the problem is not related to the tips (as you pointed out, a new tip does the same thing).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andreas M 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 27
总计 541
