跳转到主内容
A tablet with capabilities to attach to a portable keyboard and function as a laptop.
Why is the tablet not noticing my internet
In settings when searching for my internet to connect it does not show my home wi fi service. I also cannot figure out how to download a QR code reader
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Hi @lorri10042
Has the device been dropped or gotten wet at all?
Try using it as close as possible to your home WiFi router i.e. <15cm and check if it detects and connects to the network.
If it does there may be an antenna problem in the device.
Here's the ifixit Unbranded UB-15MS10 Motherboard Replacement guide that may help.
The single black antenna cable can be seen in the image in Step 4. going from the mounting post on the left side to the motherboard on the right.
As for a QR app, once you have the WiFi working here's an app that's available from the Microsoft store that you can download and install.
这个答案有帮助吗?
得分 1
添加一条评论
Is your home Wi-Fi router using the 5 GHz band? If so, your device may not be able to see it because it only sees 2.4 GHz connections, not 5 GHz connections. You can try reconfiguring your router to use 2.4 GHz to see if the problem is resolved.
这个答案有帮助吗?
得分 0
添加一条评论
How about starting with some troubleshooting steps instead of a major replacement????????????
If you are in an area where there are other wifis, does it see ANY wifi networks?
If not, it is internal to your unit and may be fixed by settings or by replacing the wifi module - not the whole MB.
If you see others, then it is your router configuration or hardware. Insure it is configure to transmit the frequency your device is looking for.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lorri 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 111
