跳转到主内容
Unbranded UB-15MS10 Motherboard Replacement
你所需要的
  1. Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Use an opening tool to pry off the memory card door located on the back of the tablet.
  2. Unbranded UB-15MS10 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two 1.2mm screws found under the memory card door.
  3. Unbranded UB-15MS10 Motherboard Replacement: 步骤 3 中的图像 1,3 Unbranded UB-15MS10 Motherboard Replacement: 步骤 3 中的图像 2,3 Unbranded UB-15MS10 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pry around the outside carefully using the black spudger to get in.
    • Putting many opening tools around the edge helps keep it from sealing shut again.
  4. Unbranded UB-15MS10 Motherboard Replacement: 步骤 4 中的图像 1,2 Unbranded UB-15MS10 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
  5. Unbranded UB-15MS10 Motherboard Replacement: 步骤 5 中的图像 1,3 Unbranded UB-15MS10 Motherboard Replacement: 步骤 5 中的图像 2,3 Unbranded UB-15MS10 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
  6. Unbranded UB-15MS10 Motherboard Replacement: 步骤 6 中的图像 1,2 Unbranded UB-15MS10 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the five 1.2mm screws from the board.
  7. Unbranded UB-15MS10 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Use an opening tool to remove the board from the case.
  8. Unbranded UB-15MS10 Motherboard Replacement: 步骤 8 中的图像 1,2 Unbranded UB-15MS10 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Detach the three ribbon cables using a spudger
    • Desolder the black, white, and red wires.
  9. Unbranded UB-15MS10 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Unscrew the two 1.2mm screws from the speaker.
    • These screws are wired to the motherboard.
  10. Unbranded UB-15MS10 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Unscrew the two 1.2mm screws of the other speaker.
    • These screws are also wired to the motherboard.
  11. Unbranded UB-15MS10 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the old motherboard from the tablet.
    • Take the new motherboard and solder the black wire of the board to the black wire of the battery.
    • Do the same for the white and red wires.
结论
To reassemble your device, follow steps 1-10 in reverse order.
另外一个人完成了本指南。
Matthew Sylvia
于03/08/17注册
280 声望
创作了2篇指南
团队
一条评论
Please where can I get the motherboard or charging IC of UB15MS10
Ayo Olowo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,202
