跳转到主内容
加入维修社区 - 创建账户
Toshiba Satellite L300 是一款由 Toshiba 设计并销售的笔记本电脑,预装了 Windows Vista 版本。该型号在 2009 年 5 月至 6 月左右售出。虽然它没有获得免费升级到 Windows 7 的资格(如今时间已过,升级也已无法申请),但运行 Windows 7 家庭高级版的效果不错,这主要是因为 Vista 系统非常占用资源。该机型也称为 Toshiba Satellite L300-04P (PSLB8C-04P01X)。
Won't boot up.
I put the machine into sleep mode then closed the lid. On opening nothing I did would wake it up. Shut it down. Would not then boot up. Tried everything. Took out battery, RAM, swapped SSD, tried booting holding down various key combinations. Lights come on, SSD flickers, but nothing appears on the screen. Thank you for any tips!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
try to clean it first and check that there isn't any falty connections, then consider making a bootable USB for a linux(I'd suggest Ubuntu or mint or Pop for easy use and lots of good youtube tutorials online) and to check that it's not a kind of software bug then try replacing the RAM as it could be faulty RAM Toshiba Satellite L300 内存条更换
hope this helps
这个答案有帮助吗?
得分 0
2条评论:
Thank you for your reply. Tried taking out the original and extended RAM cards and swapping over. No joy. It's a Windows 10 set up (been running that since Windows 7 was no longer supported.) Won't boot up off a boot able USB stick and pressing F8 and F12 on start up have no effect. I suppose I could try a new RAM card.
完成的
I meant to add that I also took out both memory modules and tried each one in the main memory slot, ie, just one at a time. I guess it's possible that they may have both become faulty.
完成的
添加一条评论
添加你的答案
K P Dawson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 255
