跳转到主内容
加入维修社区 - 创建账户
发售于2016年11月.PS4 Pro升级了硬件,使之能够支持4K游戏以及流媒体视频。
DVD problem and stability issue
Hi everyone, I bought a PS4 Pro and it appears to be working perfectly. At first glance everything seems to be fine, just a little slow in loading the system. I try the DVD player, and when I install the games it installs them, but makes strange noises as if it's struggling. I thought it was the reader that was faulty, perhaps the lens, when in the evening I turned it back on and it checked the database, failing, and after a couple of attempts (not even accepting the manual update), it turned back on as if nothing had happened. Now, given that the system in general seems quite slow, could it be a nearly dead hard drive? Or is the reader giving in too? Maybe the lens?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi there!
According to your issue, it does look like that the Hard drive is getting bad.
I recommend to replace this one first and see how that goes!
While you are there, maybe it's worth it to replace it for an SSD! Faster, less power consumption etc.
When replaced, you need to install the new PS4 software on it, which can be found here: https://www.playstation.com/en-us/suppor...
Make sure you get the "PS4 Console Reinstallation File". Not the update file.
Guide for how to replace the HDD: PlayStation 4 Pro 硬盘更换 It's really easy to do!
Please let us know how it goes!
这个答案有帮助吗?
得分 1
4条评论:
Alright, i'm gonna replace it and see the results!
完成的
Great! HDD drives could also make some noise (when they are starting to die). Please let us know how it goes and good luck!!
完成的
Hi, i swapped out my old hdd with a new ssd, and it works flawless! Thanks a lot, problem solved!
完成的
Good to hear!! Have fun gaming and take care :)!
完成的
添加一条评论
添加你的答案
Lollo Modding 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 17
总计 168
