My 2015 BMW F700 GS won’t start
Hi,
My 2015 F700 GS won’t start, the battery is at optimum health and has no issues.
When I start the ignition the lights and all things on dashboard do come alive like it would normally, no sign of oil required or low gas.
The fuel pump also makes the sound of one bleep indicating it is working.
What could possibly be the issue?
I am in cold weather, minus 5 but the motorcycle was not starting since November 4 which was not cold at all.
Please help.
Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
5条评论:
@sanketmore does the engine crank over (is the starter working) or does it not do anything?
完成的
Yes, the starter works. But engine doesn’t fire up.
完成的
@sanketmore one more check. Do you have spark on the spark plug? I usually just pull the plug connector and use a different sparkplug and hold it close to the engine block. Then try to start your bike. See if you have spark.
完成的
@oldturkey03 I need to check that, where can I locate the spark plug?
完成的
@sanketmore check something like this video at about 5:20 to learn about the spark plugs
完成的
添加一条评论
