My right trigger doesn't work at all.
Although it's not alot, here's all of the information I've got on this issue:
It can not be a software issue, I've tried reimaging.
trigger_cal always results in it being 1700, 1000
The issue started off with full presses not working before evolving into this.
2条评论
The trigger mechanism uses a Hall Effect Sensor. Which detects the presence (or absence) of a magnetic field. What values does the left trigger give when you calibrate?
This could be as simple as an alignment issue to be honest.
由 Alisha C 完成的
@flannelist My left trigger gives 1658, 672.
由 tweetedlands 完成的
