跳转到主内容
完整的拆卸和安装指南,支持大部分的 iPods, 包括 iPod original, mini,shuffle,nano,classic 和 touch。
6222 个问题 查看全部
How to connect a audio-device to a iPod-dock?
The other way:
I have got a radio with an iPod-input (no other). I want to connect an other audio-device with an cable to it. I connected the 3 audio-pins from the socket with a cable but it don't work, nothing to hear. The display of the radio only tells "No iPod found".
How can I simulate an iPod to the socket, so the signal "goes through"?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
You'll find multiple interfaces you may be able to use here:
http://www.installer.com/iPod/
这个答案有帮助吗?
得分 1
1条评论:
Fine, Thank You!
But I have the requirement to make it myself ;-)
完成的
添加一条评论
it sounds like you already know the iPod dock connector pinout - I've heard that some accessories look for power provided by the iPod on pin 13 of the dock connector to detect it's presence. have you checked that out?
of course there's also the serial accessory protocol used by some dock accessories, but I'm not sure if a radio/speaker dock would use that to detect simple presence of the iPod
这个答案有帮助吗?
得分 1
2条评论:
Thats the way it works! When I put the 3.3V on Pin13, the signal goes through. But before I had to connect the GND-pins among themselves, so the radio "noticed" a iPod is connected. Thanks!
完成的
I know this is a super old thread, but is the way to fix this simply to solder dock pin 18 to dock pin 13?
TLDR my dock snapped off and I only need it to send the signal to the dock that the ipod is present , even though it is not. Thanks!
完成的
添加一条评论
There is a hardware called DockBoss+, which does this job.
http://www.cnet.com/news/dockboss-plug-a...
这个答案有帮助吗?
得分 0
添加一条评论
You can use a Raspberry Pi Zero W / Zero 2 W together with the Poolside Factory Dock Adapter to stream music wirelessly to the 30pin connector via AirPlay 2 or SpotifyConnect. The adapter powers the Raspberry Pi and contains a HiFi DAC that takes the digital audio signal and creates a HiFi audio signal going into the 30pin dock connector. It also creates the signals for your dock to think an iPod is connected. These are the instructions for how to configure the Raspberry Pi for Airplay 2.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ilja 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 32
总计 3,295
