跳转到主内容
Lenovo ThinkPad is a Windows 10 laptop with a 15.6-inch display and 6-GHz Intel Core i7-6600U CPU, 16GB of RAM, a 512GB SSD and an Nvidia Quadro M500M GPU with 2GB of VRAM
How to remove the base to upgrade the RAM?
I cannot find a video that describes how to do it and I think something is stuck in my laptop. I cannot remove the undecover to upgrade the ram,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @danielcard51553
Before opening the laptop read Disabling the built-in battery on p.66 (p.72 of 112 pdf) of the hardware maintenance manual for the laptop.
Then go to p.68 and p.77 (74 & 83 of 112 pdf) respectively, to see how to remove the battery, base cover and memory modules
According to the specifications for the laptop, it supports 32GB max / PC3-12800 1600MHz DDR3L, non-parity dual-channel capable memory modules in two DDR3L SO-DIMM sockets i.e. 2 x 16GB modules.
这个答案有帮助吗?
得分 1
1条评论:
I figured it out yesterday, my issue was that the bottom cover would not come out. there was GLUE between the cover and the fan exhaust...
It came out, not nicely but it did. I cleaned the glue.
完成的
添加一条评论
最有帮助的答案
How to upgrade Lenovo Thinkpad P50 your P50S maybe similar. Let us know.
This one requires removing the keyboard to get to the RAM
Click here
and this one does not.
Here
这个答案有帮助吗?
得分 1
1条评论:
This is not true
完成的
添加一条评论
添加你的答案
Daniel Cardiel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 93
