跳转到主内容
焊接是一种通过在两块金属之间熔化另一种填充金属来连接两块金属的方法。焊接有很多种,但本文旨在教您电焊接的基础知识。
wire not melting with gun fully hot...What could be reason?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Are you sure it is solder and not something else? What does the label say the % tin or % lead is in the solder?
完成的
Do you know what temp your tip is at? What are the specs of the solder that you are using as that determines the melting temp. As mentioned, are you sure it's solder or could it just be a few wraps of wire that looks like solder. If you have some known solder, try that. If you are sure the tip is hot enough, then replace what you are trying to use as solder as it might not be solder.
完成的
添加一条评论
1个答案
最有帮助的答案
A lot of this depends on what type of iron you're using and how well your equipment was taken care of.
Solder needs a few things to melt (and adhere to the iron). A sufficient temperature is a start, but soldering is built on a few principles, not just getting things warm enough. The biggest reason that solder usually will not melt, or stick to an iron is oxidation on the tip. You'll want to make sure it's shiny, rather than dull, discolored, or burnt. This can also block or impede the transfer of heat.
Solder wants to melt and stick to more of itself, or anything copper. So you'll need to have a good clean surface for effective solder. If you don't have a means to clean your iron, that's where I would start.
Many tips also have a hot spot where you'll be able to melt solder the most readily. Usually this is towards the end of the tip, but form factor and quality will affect this. A hook type tip will likely be hottest and the bend rather than the tip of the hook.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Abhay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 101
