跳转到主内容
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 个问题 查看全部
How do I put the adhesive on my Ipad2?
I bought the front panel and replaced it for my Ipad2, and it came with adhesive but i do not know how to put the adhesive on or where to put it on because the guide did not say
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
It goes on the Digitizer itself. Google search iPad 2 digitizer, click on images, and you should be able to find a screen that has adhesive on it; use that image as your guide.
这个答案有帮助吗?
得分 1
添加一条评论
Here's the thread that talks about how to install the adhesive for the iPad 2, there is a picture that shows exactly how the adhesive for the iPad 2 is installed. You do install the adhesive on the screen first, then install the screen onto the iPad frame. Some people put the strips on the frame first, but they are not designed that way.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
weimersc 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,031
