replacing screen adhesive strips
do you attach the 3M strips to the glass or case,
And is there a guide to the placement of each strip
I had huge problems after replacement to fix the frontpanel well. Maybe because of this the gave me two sets of adhesive tape... So anyway better to use two layers of the 3M tape if available...
My final solution after bad sticking frontpanel was at the end to use silicone sealent... now it sticks perfect and works also as a good sealing for dust...
这个答案有帮助吗?
What kind of silicon sealant?
Here is the guide:
http://ipadscreenrepair.com/repair-guide...
Scroll down on the page for adhesive diagram.
这个答案有帮助吗?
here is the placement of the pre-cut 2 sided tape for ipad 2
[http://www.ipadscreenrepair.com/wp-conte...
it is very cheap and easy...
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 44,179
2条评论
Replacing screen
由 martinezramon974 完成的
martinezramon974 do you need help? if so please post a detailed Question on the question form
由 Jimfixer 完成的
