跳转到主内容
加入维修社区 - 创建账户
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
MacBook isn't indicating that it's charging after battery replacement
I recieved my iFixit battery replacement kit yesterday and worked on it all night following each step all the way through. I plugged in my laptop to charge it as per the instructions and waited a little while before attempting to turn it on. There is no indication it was charging at all, and it didn't do anything when pressing the power button. I left it connected to charge over night and still dead this morning. I opened up the base and went through all of the connections I could see and don't think I'm missing anything, although I didn't pull the motherboard out again. The one thing I did damage id the board connector for the left speaker as it ripped away from the board when I was trying to pry it up. I had consigned myself to just not having functioning speakers, but now I'm worried it's causing another issue?
Please help me with troubleshooting! What could I be missing here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@ajfraser post an image of the damaged area on your logic board. Use this guide for that. You can only add images to answer or question not comments.
在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
It sounds like the BMC cable is not connected. Can you post a picture of the two ends of the cable and the connection so we can see things.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
A.J. Fraser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 90
