跳转到主内容
The DeLonghi ESAM family of products is a line of automatic coffee machines for making lattes, cappuccinos, espressos, and other drinks. Look for the model number ESAMxxxx on a sticker on the back or bottom of the device.
Delonghi ESAM4200S stuck on red triangle when power on
Hello, I have a Delonghi ESAM4200s with the red triangle led that lights up and stays on when I switch on. (Sometimes, 1 cup and 2 cups leds are on too).
I used the test mode (press and hold 1 cup + steam and switch on), everything worked perfectly except the thermoblock. No led turns on when I pushed the « Rinse » button, it doesn't heat up. So I checked its resistance and it was good (38ohms). The thermofuses are good too. The thermosensor is good too (10kohms). I tried replacing the power supply board and nothing changed. I checked the all switches and all works fine.
Do you have any advice on what I should check?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
@dylanbeaucamp let's see if our coffeemaker guru @vauweh can help you out with this.
完成的
Thank you for your help
完成的
添加一条评论
1个答案
最有帮助的答案
@dylanbeaucamp I suppose, a TRIAC that controls the heating could be defective. It is attached to the large black heat sink on the motherboard. Desolder it, determine its type and replace it. Don't forget to apply new thermal paste.
Or: try getting a used motherboard e.g. from eBay.
这个答案有帮助吗?
得分 1
10条评论:
It's weird, I replaced the power supply board with a new one and I have the same problem. I'll check the triac anyway
完成的
Here are more details on the original fault:
When I plugged the machine in with the original power board no problem. I pressed the power button and it lit up and did a rinse cycle. Hot water came out correctly for a few seconds and then it went into fault mode (fixed red triangle and 1 cup, + 2 cups flashing).
I changed the power card with a new one and since then it hasn't started at all, I get the red triangle as soon as I switch it on.
In test mode with the old power card, everything worked fine.
完成的
Strange behaviour, I dont have a really good idea without seeing the device, sorry for that.You say, the water was hot? It remembers me a little bit to an issue which I had with a broken motor. Does the drive move smoothly, when using the testmode with the other PCB?
完成的
I've put the old power board back in temporarily and here's the problem on video, which will be easier to understand.
https://youtube.com/shorts/1RKHtACjCAI
完成的
I added the video of the motor test. It looks like it move smoothly. The hall sensor works correctly because the ECO led flashing when the drive move.
https://youtu.be/sYE6E6T6cT0
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Dylan Beaucamp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 65
总计 544
