跳转到主内容
加入维修社区 - 创建账户
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
System Files Are Corrupt
I've gotten into fixing consoles and recently came across two wii's that were broken. One of them I was able to get up and running pretty fast, the other one however is uh, questionable. It's got the dreaded "System Files Are Corrupted" screen, and normally I would be able to access different settings to attempt to fix it. But the previous owner has seemed to try to fix it with a factory reset, sending the wii back to its factory default, and as soon as I try to set it up the screen flashes a little, and then just prompts me with the Corrupted file screen. Even when trying to boot to matienence I get the same issue. So I'm wondering if somewhere out in the wii nerd/homebrewing world if there is a piece of 3rd party software or a random button assignment that would give me some kind of access to any type of settings to try to fix it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi Jackson!
Please try the following procedure:
Turn on the Wii, now press and hold the reset button imediately after you turned it on. Hold the reset button and hopefully you will get a new screen now “Priiloader”. Stop pressing the reset button.
From here you should boot to the “Home Menu”. You can also adjust the following setting: “auto-boot, to the original Wii home menu”. Please do this, now you should be able to access the Wii again.
Please let us know how it goes!
这个答案有帮助吗?
得分 1
4条评论:
Hi! Unfortunately this did not work, as it just boots to the regular screen and does the Corrupted screen again, is there any other way? Please let me know.
完成的
Ah, then Priiloader wasn’t installed at all :(. Is the SD card still there? Or is there no SD card at all? If not, then I’m afraid it’s bricked... You do need to replace the NAND at that moment. Unfortunate it's very difficult to replace it and you need another broken (donor) motherboard with a different issue. The other option left is to replace the motherboard for a working one. This is way easier, but more expensive. The drive it's PCB does not need to be transferred.
完成的
This actually works for me since I got the same error with or without SD card and I was able to get a game reading and I'm playing it right now with no errors, thank you!
完成的
My pleasure! Have fun gaming Ezra :)!
完成的
添加一条评论
添加你的答案
Jackson Byard 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 19
过去 30 天: 102
总计 1,607
