How to use ch341a programmer to flash EFI
Hello there. I've a macbook pro retina mid 2014 and at the moment I have a firmware lock problem. I've bought a ch341a programmer on amazon to try flash the EFI and remov the password but I've noticed that the SOIP8 clip will be unable to attache on the chip. I'm not sure if this is because the clip is damnaged or if because this clip can't be used with my series of macbook, is there anyone that can help me or explain if this is possible with the equipped EFI chip on this model?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
7条评论:
I would contact the seller to double check if you got the correct part.
完成的
so it's possible to use the clip on this soldered chip?
完成的
@ziobru - I have no idea what you got here for a tool, and that’s not how I would go about it. Which is why you need to talk with the people who sold you the tool and maybe the person who made the tool.
完成的
@ziobru on the one I have, it is necessary to place the IC in the programmer. I can't connect to in-circuit IC's with that one. Let's see what your programmer looks like 在已经存在的问题里加入图片
完成的
@oldturkey03 i edited in a photo to his question, i have 4 of them but never used for bios yet, i only use 1 atm for uart
完成的
显示更多的2条评论
添加一条评论
