跳转到主内容
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Will a T9600 CPU work in Mac Mini A1176?
I am interested in upagading a mid 2007 Mac Mini to the maxium RAM and CPU the logic board can support. I want to know if a T9600 CPU and 4GB or 8GB of RAM will work if this processor works?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I believe the T9600 uses the P socket and your machine an M socket. It will take a T7600. See this previous answer on a similar question: Core Duo CPU upgrade to Core 2 Duo CPU?
Here's some info on the M socket: http://en.wikipedia.org/wiki/Socket_M
UPDATE
GeekBench scores should look like this:
MacMini 1.5 Ghz solo about 1400
Mac Mini 1.66 Ghz core duo about 2100
Mac Mini 1.83 Core 2 duo about 2350
Mac Mini 2.0 Core 2 duo about 2600
Mac Mini 2.0 2009 about 2750
the 2.26 about 3200
http://browse.geekbench.ca/mac-benchmark...
这个答案有帮助吗?
得分 2
2条评论:
Thanks Mayer. Well, if the socket is different, I guess the T9600 is a no go. Do you know if the T7600 is the fastest M socket processor that can be used in this machine? Also, will the machine have the same 3+GB RAM limitation with the T7600? I was wondering if the ability to address RAM is a function of code on the processor, or other chip(s) on the logic board.
完成的
The fastest socket M processors are Core 2 Duo Mobile T7600 and core 2 Duo Mobile T7600G. The T7600G has unlocked clock multiplier and can be overclocked, but it's very expensive and very difficult to find.
The fastest CPU known to work on the MacMini isT7600, that I know of, is the 2.33 GHz. RAM capacity has remained the same on all the machines I have upgraded.
Here's an eBay seller that seems to know his stuff on this CPU: http://www.ebay.com/itm/Apple-iMac-Mac-M...
完成的
添加一条评论
添加你的答案
rickm65 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 7,343
