跳转到主内容
Released on 17 February 2022
Touch not working properly Automatically touches happens
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
thats weird tho, i have the same issue, no automatic touches, this happened very unsually
完成的
changed from an answer left on Phones display is not working to its own question
完成的
添加一条评论
1个答案
最有帮助的答案
The phenomenon known as "ghost touch" results from a bad connection between the digitizer and the motherboard, allowing signal noise on the line which gets interpreted as touch inputs by the processor. The interface between the glass the digitizer circuitry is printed on and the flex cable going to the motherboard is delicate and easily broken. Unfortunately, it's not repairable so the only solution is to replace the screen. Assuming you have the same phone as the original poster, you can use the instructions given in my answer to fix your phone.
Here is a link to that answer.
Phones display is not working - oneplus nord ce 2 - iFixit
这个答案有帮助吗?
得分 2
2条评论:
I want to repair it
完成的
@prashantsh30375 You'll have to be more specific. What's broken that you want to repair? If we're still on the subject of ghost touches, that's already been answered, and if it's a different subject or a different phone, you need to start your own question with a good description of exactly what the issue is, how it started and what you've done to troubleshoot the problem.
完成的
添加一条评论
添加你的答案
myself Chotu 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 26
总计 255
