跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
LCD Replacement iMac 20"
Can you replace a LM201W01 (SL)(A3) with a LM201E01 (ST)(B2) or LM201W01 (A5)(K2)? Not sure what the numbers in () represent.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you also give us the Apple part number? It should be something like 661-3881 or 661-3895. Also the last three figures of your serial number would help.
完成的
Sure I have the same question I have no chime on two 2006 32 bit [U2P and U25} one came with LCD (ST) (B2) and the other (SL)(A3) Should I try a late 2006 inverter in this early 2006 or try to stick with inverters that say they are for this model. The sl-a3 works and seems to fit better for a late 2006
完成的
添加一条评论
2个答案
已选择的解决方案
The suffix provides EDID or Extended Display Identification Data. AFAIK each manufacturer can make/use their own codes... e.g. SL may mean Silver, A may mean black (surrounding the crystals) B2 could mean glossy, or A3 may mean matte. I think I read someplace that there's possibly 500 different compatible screens for most computers.
If you follow the link you can see that getting the correct LCD is much more complicated than purchasing a light bulb or set of tires for your car.
Good Luck,
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
The EDID info is on a EPROM on the scaler card and not the LCD.
完成的
添加一条评论
最有帮助的答案
You can use suffixes SLA1 and B5 as a substitute for the SLA3. The A5K2 will not work. The SLA3 uses LVDS to communicate with the scaler card and the A5K2 does not use LVDS.
这个答案有帮助吗?
得分 2
1条评论:
@Stevenpundt - It appears you know your displays! How about creating a technique guide?
完成的
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 1,577
