Can't enter safe mode on new 3ds xl
When I try to enter safe mode holding by down all the button combinations, it just flashes gray for like 1 frame and then stays on a black screen untill I force shut it down by holding the power button down. Even after waiting for around 15 minutes it still doesn't boot up. Does anyone know the solution?
Update (10/02/24)
I forgot to mention but my new 3ds xl is modded.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
8条评论:
Hi!
What is the reason that you need to boot into Safe mode? Is it failing to boot as normal?
完成的
It can normally boot up but I need the safe mode as it can restore critical nand files which a system update can't do from my experiences. Is this normal if i mod a 3ds and region change it? Thank you!
完成的
Not sure about modding :(… sorry! @darthmango knows more about this! Darthmango can probably help you out with this!
完成的
@darthmango please help me you are 3ds expert
完成的
I'll try. First thing is to check your luma version. Boot the console while holding SELECT and look for the version number on the top screen
完成的
显示更多的3条评论
添加一条评论
